It is currently Mon Jun 15, 2026 9:32 pm
 Post subject: Hydro or Mech?
PostPosted: Mon Nov 15, 2010 1:44 am
Hi,
I can possibly get hold of an engine to use as a rebuild 'blank'. It has the tube-less cylinder head.
How can I tell the seller to find out if it has hydraulic or mechanical lifters?
Thanks a lot,
60 Ply
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Mon Nov 15, 2010 4:25 am
The heads with hydraulic lifters has a different valve cover if I remember correct.
PostPosted: Mon Nov 15, 2010 5:40 am
the front of the hydro engine has a small dogleg ....the solid is straight
81 up hydro
PostPosted: Mon Nov 15, 2010 6:24 am
When you say the front of the engine, do you mean the front of the block casting? Whereabouts?
I'll ask the seller if he can get hold of a picture.
Stock 60 225
Right Hooker
PostPosted: Mon Nov 15, 2010 6:54 am
Easiest way is to look at the side of the block, under the manifolds, for the casting date.
PostPosted: Mon Nov 15, 2010 9:29 am
The valve cover and head is wider on Hydraulic engines.
The "dog-leg" notch is on the lower, front right corner of the head/valve cover.
