It is currently Sat Nov 21, 2026 5:28 am
PostPosted: Mon Nov 15, 2010 6:09 am
Most of the questions here around 2 bbl carbs (super six) seem to reference Carter BBD carbs,, were Holley 2bbls also used?
if either is available, is one preferred over the other,
and what years were they uses?
thanks
PostPosted: Mon Nov 15, 2010 6:11 am
The other slant super six carb is the Holley 2280
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Nov 15, 2010 6:46 am
They both have their pros and cons, and fans and enemies. My dad had a Carter BBD he could never get to run right. I had a Carter BBD that would never get quite right. Some people say the same things about the Holley. Both will do all right, but I adapted a Holley 350 cfm 2 bbl and never missed the old BBD.
PostPosted: Mon Nov 15, 2010 10:04 am
Like any carb, some will run fine and others wont. If you buy a remanufactured one or an old worn out one, then it wont run right. Too many people will buy a remanned Carter BBD and then claim all BBD's are trash because theirs didn't run right.
PostPosted: Mon Nov 15, 2010 10:37 am
I've had a few Carter BBDs on both Super Sixes, and 318s. Other than having to get the bushings redone on the throttle shaft, I've not had any problems with them. I haven't run a Holley (yet) to be able to compare.
Users browsing this forum: Bing [Bot] and 9 guests
