It is currently Sat Nov 21, 2026 8:04 am
PostPosted: Mon Nov 15, 2010 2:11 am
so which one is for each application??
whats the difference?
PostPosted: Mon Nov 15, 2010 5:50 am
Bronze one was for the Aussie "Hemi" six. Iron only for the slant.
As far as I know.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Nov 15, 2010 9:24 am
I made-up a batch of bronze (really a nickel-bronze alloy) SL6 oil pump gears for use with steel camshafts. (roller cam applications)
An iron gear wears-out fast when use with a steel cam.
I also heat treat (carborize) the factory cast iron gears to give them a harder "skin". (case hardening)
PostPosted: Tue Nov 16, 2010 4:39 am
Would you recommend getting the stock gear hardened and pressing it on a key way melling kit, is this bad practice? Or get the key way gear case hardened?
PostPosted: Tue Nov 16, 2010 6:01 am
Ahh ok didnt know your made a batch Doug.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Tue Nov 16, 2010 10:32 am
Either way works better then using the gear that came on the new Melling pump.
I can provide both types of gear, if needed.
(Heat treated factory or aftermarket gears, with a keyway slot)
