It is currently Sat Jun 20, 2026 6:57 am
PostPosted: Mon Nov 15, 2010 10:36 pm
I have a '64 Dodge 330 ( I know it's not an A body, but bear with me... :D )
It's a 225 slant six with three on the tree and manual steering and I'd like to convert it to power steering. How would I go about doing this?
Oh, and I'd like to convert it to front disc brakes, would this have any bearing on the PS conversion?
Thank you, slant six forum!
'64 Dodge 330
225 SL6
PostPosted: Mon Nov 15, 2010 11:04 pm
You should be able to directly bolt in a small sector shaft (1972 and earlier A and B body car) power steering gearbox. You'll also need the shorter steering column shaft or entire steering column. The power steering pump and brackets can come from just about any slant six car or truck, but I believe the early pump with the round reservoir and large return hose is period correct.
The steering and brake changes can be handled independently.
