It is currently Mon Nov 16, 2026 11:57 am
 Post subject: Dipstick
PostPosted: Tue Oct 26, 2010 6:21 am
Hi all,
Looking for a dipstick for a 1960 A-904. I believe the parts exchange from 1960-66, I think one of the Doc's posts elsewhere on this forum stated this.
I've put an ad on here but had no luck, so does anyone know where I can get one new?
Alternatively, if anybody could give me all the necessary dimensions to make one, then I'd happily do so.
Thanks a lot,
60 Ply
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Tue Oct 26, 2010 2:53 pm
BELIVE IT OR NOT I GOT ONE FOR MY 63 VALIANT FROM THE PART DEPARTMENT AT THE DEALER. About two week ago
PostPosted: Tue Oct 26, 2010 3:31 pm
That is strange, back housing of the water pump for carbed 2.2L is NLA since 2003 and I needed one. Not the other half that contains rotating pump. So I'm modifying a TBI water pump to clear the fuel pump so I have caravan drivable for awhile. Once I have the pump out, crack in radiator nipple will be repaired. Housing is aluminum and is weldable.
Cheers, Wizard
PostPosted: Tue Oct 26, 2010 3:41 pm
I have a few used ones... if it comes down to that.
PostPosted: Mon Nov 01, 2010 7:12 am
Hi Guys,
Thanks for the replies.
Doc, very interested: you have a PM.
All the best,
60 Ply
Stock 60 225
Right Hooker
PostPosted: Fri Nov 19, 2010 3:51 am
Anybody have a part number for the 1960-66 torqueflite dipstick?
I might have more luck with the chrysler dealer if I can give them a number.
Thanks a lot,
60 Ply
Stock 60 225
Right Hooker
PostPosted: Fri Nov 19, 2010 5:23 am
Part number for a 66 904 filler tube is 2538 834. for the stick it is 2466 302.
Unable to locate filler tube, located stick at these dealers.
http://www.bradsnosparts.com/
http://collectorsautosupply.com/
http://www.dpmotorparts.com/
I have not purchased from any of these vendors.
PostPosted: Fri Nov 19, 2010 5:30 am
Hi Charrlie,
Thanks for the response. Don't suppose you know the p/n for the 1960 version do you? I think 66+ was different (a few cross references seem to agree).
Stock 60 225
Right Hooker
PostPosted: Fri Nov 19, 2010 6:35 am
Hi Charrlie,
Sorry, I only have parts manual for 1966,67,68,69.
Users browsing this forum: Amazon [Bot] and 1 guest
