It is currently Wed Jun 24, 2026 10:50 pm
 Post subject: 73 engine into 64 car
PostPosted: Mon Nov 22, 2010 5:46 pm
My old 64 dart 225 is getting tired and smoking so I'm going to put a 73 225 and 904 into the dart. Is there any issues I don't know about by doing this swap?
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Mon Nov 22, 2010 5:57 pm
You haven't listed what needs to be done so my bet is that you don't know the issues involved with this swap.
Someone once told me you can't know something you don't know. Maybe you'd like to rephrase the question? 8)
PostPosted: Mon Nov 22, 2010 6:21 pm
I know I need a diffrent driveshaft, will have to go to a floor shifter stuff like that but other than those things is there anything else that really has to be changed?
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Mon Nov 22, 2010 6:39 pm
6 Pack Dart
If it has a 904 in it now all you will need is the adapter for the small snout converter to crankshaft. Then use all of what you have now.
Richard
PostPosted: Mon Nov 22, 2010 6:44 pm
If your transmission is sound keep it. Get the bushing for the crank pocket to properly support the nose of the torque converter. In 1968 the nose of the torque converter and the pilot hole in the crank got larger. Swap oil pans, oil pickup, dipstick with tube (optional) and the manifolds (also optional). I also like the appearance of the early valve cover better so if it were mince I'd swap that too. Swapping a slant is a decent weekend project. When I was 19 I pulled the 225 from my '66 Dart and installed the fresh engine in about 8 hours unassisted.
PostPosted: Mon Nov 22, 2010 6:52 pm
Ok where can I get the bushing so I can use the the newer motor with the old trans? parts store?
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Mon Nov 22, 2010 6:56 pm
Doug Dutra has a supply.
PostPosted: Mon Nov 22, 2010 7:14 pm
Thanks guys Thats why I come here quick responses.
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Tue Nov 23, 2010 8:57 am
As noted, I have the adapter bushings...
Send me a PM for cost & shipping details.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
