It is currently Sun Nov 22, 2026 9:18 am
The weigh difference is?
Poll ended at Mon Dec 06, 2010 4:45 pm
100 grams 0%  0%  [ 0 ]
150 grams 44%  44%  [ 4 ]
200 grams 11%  11%  [ 1 ]
250 grams 44%  44%  [ 4 ]
Total votes: 9
 Post subject: 170 rods. Stock and not.
PostPosted: Fri Nov 26, 2010 4:45 pm
The stocker is 5.70" center to center. The pretty rod is 6.00" C-C. What do you thing the weight difference is?
BTW, the next race 170 will use the rod on the right with a 1.25" CD piston, maybe an off the shelf Neon piston. The pin is the right size.
Crud, forgot the picture!
PostPosted: Fri Nov 26, 2010 4:51 pm
Before answering, what material is the "pretty" rod? :lol:
PostPosted: Fri Nov 26, 2010 4:56 pm
Some fancy kinda steel.
PostPosted: Fri Nov 26, 2010 5:04 pm
6 Pack Dart
Is it an H beam ?
PostPosted: Fri Nov 26, 2010 6:43 pm
OK, Mine were 240 Grams lighter than stock, so I tossed 250 up there. Those are even cleaner than the ones I had worked up for the hooptie! :D
PostPosted: Fri Nov 26, 2010 8:15 pm
Is it an H beam ?
Yes. It's also got a little hole the length of the rod to oil the pin.
PostPosted: Fri Nov 26, 2010 9:40 pm
248.77 lighter.could get closer with better pics.Wilfred
