It is currently Fri Nov 13, 2026 9:04 pm
PostPosted: Tue Aug 05, 2003 2:32 am
I want to up the power in my Valiant('62 with a 225 and auto), and want to know what are the best bolt ons for these engines? I keep hearing that you cant get a 4 barrel to run good on a stock engine.
I want to put a four barrel carb, a Petronix electronic ignition(and a wider advance curve), and headers. I was contemplating a weber 2 barrel versus a 4, maybe a single side draft on a modified stock intake(just for something different and good hood clearance). Any and all help would be great.
-Jesse
PostPosted: Thu Aug 07, 2003 1:29 am
Anyone :?: Well I'll ask another question, was there ever an aluminum intake that came stock(besides the super six)on the \6?
-Jesse
 Post subject: Yes, the 70's....
PostPosted: Thu Aug 07, 2003 7:36 am
There are stock 1 barrel intakes that were aluminum.
The best ones are the Feather Duster/Dart Lite cast aluminum intakes, after that you can grab the 'electron welded' models from any 1977-1987 1 barrel equipped truck. using an aluminum 1 barrel manifold over a cast iron manifold saves about 7-10 lbs (weighed out a set to see how much I'd lose when going to an iron super six setup...)
:wink:
PostPosted: Thu Aug 07, 2003 11:28 am
I am pretty sure they made aluminum Super Six (2bbl, Carter BBD) intakes as well. Questionable build quality on those too, I've heard.
PostPosted: Thu Aug 07, 2003 4:02 pm
I asked because I don't want to cut up a Super Six manifold, I plan on doing a single side draft Weber and I want to get rid of as much weight as posible.
-Jesse
PostPosted: Thu Aug 07, 2003 4:54 pm
I've seen an aluminum one piece 1 barrel with a '61 dated part #.
Cecil
 Post subject: best add-ons
PostPosted: Thu Aug 07, 2003 6:10 pm
I personally bought the aluminum 2bbl intake from mopar performance and went to prolinefuel.com and got the 32/36 weber for the car. Only thing now is to get the Lokar universal linkage for the car.
PostPosted: Sat Aug 09, 2003 11:06 am
The best ones are the Feather Duster/Dart Lite cast aluminum intakes, after that you can grab the 'electron welded' models from any 1977-1987 1 barrel equipped truck....)
:wink:
Little known secret.... 1986-87 S6 trucks have a very nice cast aluminum intake that looks EXACTLY like the cast iron ones. Magnet will not stick to it.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 5 guests
