It is currently Thu Oct 01, 2026 8:36 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Mon Nov 29, 2010 6:25 am
I am planning on the Erson 280/270 cam degreed at 100. Should make a solid difference and be also very docile with 9.5:1.
PostPosted: Mon Nov 29, 2010 9:16 pm
Rick, you make a good point that is impressive now that i think about it. I guess i'm just itching to see a big cube slant blow some records away :)
Kev
PostPosted: Tue Nov 30, 2010 8:15 am
At some point, this motor may find its way into one of my lighter cars, with maybe a little boost? Let's see ... 8 psi, 258", in Project V - 11s, 10s??
 Post subject: Ideal
PostPosted: Tue Nov 30, 2010 8:30 am
I think that would be a great way to go really fast. With the big cubes and a turbo there is no need to wind it over 5500. That would be a cool ride.
Rick
PostPosted: Mon Jan 03, 2011 7:12 am
now i am wondering.........you guys who have cut and welded the crank, do you think welded rods woud work? properly welded and treated rods should be able to hold up to the lower rpm this engine would be running?? if the crank holds up, woulndt rods?
http://www.youtube.com/watch?v=uTpRfREYa9Q
http://www.youtube.com/watch?v=FpkWjmP0 ... re=related
looking at that first clip: a cut low on the rod angled up and away from rotation might work. this would reduce the shearing effect on the weld, staying away from the highest stresses on the rod.
71 valiant 225, 904, 7 1/4
69 W200 power wagon 318, np435, np205, d44 front, d60 rear
PostPosted: Wed Jan 05, 2011 9:24 am
Welded rods sounds scary. Why do you need to weld rods? The '76-down 225 rods are wide enough for about anything. Smaller diameters can be had with rods from a different engine.
Users browsing this forum: DuckDuckGo [Bot] and 45 guests
