It is currently Mon Nov 16, 2026 7:49 am
PostPosted: Tue Nov 30, 2010 1:45 pm
i'm having some trouble with my 4 speed manual trans.
first off, i had the clutch replaced and adjusted.
i changed the fluid
when the truck is off it goes thought the gears fine.
when the truck is started 1-4 are very very firm to put into gear.
reverse grinds and has to be slammed in to be engaged.
i'm thinking its my pressure plate or throw out bearing.
i wanted to get some more opinions on this before i take it apart.
i would really appericate any insight at all. the 4 speed is behind my slant and everyone on this forum has always helped me alot.
thanks
-frank :D
PostPosted: Tue Nov 30, 2010 2:20 pm
It sounds like the clutch is not releasing completly, does it shift OK with the engine off?
PostPosted: Tue Nov 30, 2010 3:01 pm
the trans shifts fine its just very very firm going into each gear.
and reverse grinds.
when i drive it and i come to a stop the trans falls into first gear right away very smoothly.
PostPosted: Tue Nov 30, 2010 3:11 pm
I agree with Doug. Check to see that your clutch is releasing all the way.
Are you putting your foot to the floor on the clutch?
how much pedal travel at the top of the throw do you have?
you may be able to adjust your way out of this predicament, though it is entirely possible you have a faulty pressure plate.
~RDE~
PostPosted: Tue Nov 30, 2010 4:03 pm
i played with it a little bit and its adjusted all the way out. im think thats a sign of failing pressure plate.
PostPosted: Tue Nov 30, 2010 4:20 pm
Pull the inspection cover and take a look at the pressure plate "fingers"...
If one is lower then the others, you have a bad p. plate.
While your "inspecting"... have someone work the clutch peddle while you look-over the linkage, any looseness or sideways deflection will need attention.
 Post subject: Also...
PostPosted: Tue Nov 30, 2010 5:49 pm
What brand of clutch is it?
PostPosted: Tue Nov 30, 2010 6:09 pm
Quality duralast from autozone lol
 Post subject: Guarentee
PostPosted: Wed Dec 01, 2010 7:17 am
Never know, It may have a lifetime warranty? A lot of stuff goes. My opinion after replacing 3 Master cylinders , with lifetime warranty, is that sometimes it is better to pay a little more and have less headaches.
Rick
PostPosted: Wed Dec 01, 2010 8:57 am
your right the next one thats going in is going to be from luk.
im doing the clutch again tonight.i let you guys know what i find
