It is currently Sat Nov 14, 2026 5:23 am
 Post subject: 74 Dart dash lights
PostPosted: Sun Dec 05, 2010 12:30 am
Don't have any, any suggestions? Fuses are good, wires are good, panel on the back of the cluster is corroded and pins are missing. Could i run a bulb straight from the battery to a toggle switch to the cluster?
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Sun Dec 05, 2010 1:37 am
Suggestions for what? Do you not have dash lights, or are you referring to a slight dimming at idle (very common with stock alternator)?
'66 Dodge Dart
PostPosted: Sun Dec 05, 2010 5:00 am
If the PCB is corroded and there are no pins back there I say you need to get a new gauge cluster or at least a new PCB to get thing operating correctly..
If there are no pins that meas no elect. getting to anything in the Gauge cluster..
PostPosted: Sun Dec 05, 2010 12:16 pm
Well, on that circular connector in the back I'm missing probably 4 of them. But also where the bulbs fit into the circuit board it is all corroded.
PostPosted: Sun Dec 05, 2010 12:25 pm
New gauge cluster is in order then...
maybe Hit up MIDI on this board - I am sure wildcat auto wrecking would have one for you and they are close to you in the Northwest.
PostPosted: Sun Dec 05, 2010 3:16 pm
I figured that might be what is happening, I might have one with my spare parts but i sent a PM to MIDI
PostPosted: Mon Dec 06, 2010 7:09 pm
MIDI isn't @ Wildcat anymore. However, their website with a phone number, etc. is wildcatmopars.com You could also post an ad in the 'parts wanted' section of the board here. There are a couple on ebay right now too. Hope that helps.
PostPosted: Mon Dec 06, 2010 8:51 pm
Thanks for the heads up. I have one of their business cards from when I went to the PIR swap meet. Thought about all american classics, I got my driver fender from them for 150 with no rust.
PostPosted: Tue Dec 07, 2010 2:23 pm
Did not know that.. thanks for the update.
