It is currently Tue Jun 09, 2026 1:34 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Tue Dec 07, 2010 12:15 am
Pinging should not be an issue at around 9-1 compression ratio. If you do get ping, a little modification to the timing curve should cure it. The reason I suggest a CR increase, is it will give a power/torque increase across the complete rpm range.
In general slant six engines had a little less the 8-1 CR from the factory (regardless of what the books say).
A cam change will (in general) have more effect in a particular narrower rpm range, and with a low compression engine, actually hurt torque, in the range where you want it.
The best way would be to raise the compression, and then match the cam to your requirements. Then play with ignition curve to really optimize everything.
PS: I hope you are running electronic ignition (but not the "lean burn").
LOL, it's ok. Ya don't know me, so there's no way you'd know. My 65 PW uses an old MSD6C box, because I didn't like the lack of power from the standard Chrysler electronic ignition ( I converted from points before I started the engine for the first time). If I can find them, I run non-resistor plugs, metal conductor wires, and a high output coil. I like LOTSA spark :)
BTW, I will be using TBI and Megasquirt when it's all done. Perhaps change over to an MSD box, too, for a little more "fire" to the plugs.
I was aware of the low CR of the slant six from the factory, but it still doesn't seem to stop some of them from pinging. And, I tend to run the cam advanced 4-8 degrees on my "bigger" cam engines, because I tend to like the lower end punch, rather than the ultimate high end horsepower.
Can someone tell me any idea how much has to be shaved to get the CR up to 9:1?
PostPosted: Tue Dec 07, 2010 5:22 am
I would opt for spiral wouund magnetic suppresion wires, espicially if you are going to add electronics (megasqirt). You will still have good spark and no RFI (neighbors will love you for it).
You have to measure how far the piston is down the bore, the thickness of the head gasket you will be using, and the size of the combustion chambers. Then you can use the calculator, to determine what size chambers you need to get the ratio you want, and "IF" that difference is like 9 cc's then you remove .0066 from the head per cc difference or roughly .059
PostPosted: Tue Dec 07, 2010 10:03 am
I do :)
That RFI, however, is fascinating. It scrambles those radar speed monitor readouts, it sets off people's radar detectors, and it makes people shut off their radios in traffic when you're waiting side by side at the lights... :)
PostPosted: Tue Dec 07, 2010 10:07 am
I don't think I've ever done this before, anyone got a link to something that runs me through the process, including the math?
PostPosted: Tue Dec 07, 2010 10:29 am
Learn from my pain:
click me
 Post subject: Re: ??
PostPosted: Sun Dec 12, 2010 6:15 am
rumor is Erson wont answer the phone anymore
Not good. Maybe they didn't pay the phone bill. :)
Rick
PBM, the parent company of Erson, will be at the PRI show on the 9th-11th of Dec. I will be there, also, and will make a point of talking with them.
Sorry guys. I got sick and didn't make the PRI show.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
