It is currently Thu May 14, 2026 4:36 am
 Post subject: Wiper blades
PostPosted: Thu Dec 09, 2010 12:30 am
I can't seem to find wiper blades for my '66 Dart. Does anybody have a good suggestion?
Also, I think the FSM says 12" for both blades, does anybody run a slightly larger blade (say 13" or 14") that works well?
'66 Dodge Dart
PostPosted: Thu Dec 09, 2010 12:55 am
Anco 3013
PostPosted: Thu Dec 09, 2010 12:58 am
I use 13" on my 64 Valiant.
You can find the 13" refills at rockauto or amazon (use the part numbers you find at rockauto at amazon)
Worse case ,you may have to figure out the manufactures part number from other size refills, then replace 14,15,etc with 13 (or 140,150.... with 130)
PostPosted: Thu Dec 09, 2010 8:41 am
I really like the cut-to-length "As Seen On TV" triple-edge blades sometimes found at Big Lots - they only last ~1 yr max, but work well and are inexpensive enough to swap often.
