It is currently Sun Sep 06, 2026 11:11 pm
PostPosted: Wed Dec 08, 2010 1:07 pm
So this morning while converting to a fancy new electronic choke I broke the bolts that hold the choke thermostat housing to the exhaust manifold...
So tomorrow I will be drilling and retapping the holes. Anybody have the correct thread count and bolt size? Or should I tap it will something a bit smaller/larger?
'66 Dodge Dart
PostPosted: Wed Dec 08, 2010 2:53 pm
Try soaking the broken stud with thin penetrating oil (not WD40) over night and then use a left hand twist drill or a center drill (try MSC Catalog) to remove the stud. Some times as you drill and the stud gets hot it will un-screw its self, worth a try. About 50/50. Even if it does not work you will end up with the pilot hole in the center to drill out with. win-win.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Wed Dec 08, 2010 4:32 pm
Those are 1/4 - 20 unc threaded holes.
PostPosted: Wed Dec 08, 2010 11:19 pm
Thanks so much Doc. Am I right to retap them the same size and thread count? Or should I go slightly larger or smaller?
I'm wondering if retapping with the same specs will damage the original thread and kill any attempt to create new threads? And if I should go bigger, what would be a good size?
'66 Dodge Dart
PostPosted: Thu Dec 09, 2010 5:30 am
Maybe you could use the correct heli-coil insert for a 1/4" bolt. Then you could use the same-sized fastener.
PostPosted: Thu Dec 09, 2010 8:43 am
Removing a broken bolt or stud is a pain but if approched right, you can restore the original thread.
The "trick" is to carefully center-punch the broken "stub" and then use a smaller pilot drill to get a well centered hole started.
Once you have a pilot hole, work with progressively larger drills, to open the new hole up to the minor thread diameter.
At this point, you should start to see a "fingerprint" of the original thread showing, then you get a tap and use it to clean-out the remaining material stuck in the "V" of the threads.
Many times, I get the "sleeve" of the old fastener to jam onto the tap, then it un-threads from the hole.
If that process fails, install a thread repair insert.
PostPosted: Thu Dec 09, 2010 2:17 pm
Thanks everybody, it all worked out and I was able to restore the original threads.
I ended up center punching both bolts and using a smaller drill bit and another bit just smaller than the threads. Almost all the bolt came out, and I got the remaining bits out using a tap as Doc mentioned.
I also got my electric choke in place and it works great, its been a good day. Now if only my magnecor wires would get here...
'66 Dodge Dart
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 20 guests
