It is currently Mon Jun 08, 2026 3:12 pm
 Post subject: carb identify
PostPosted: Wed Dec 08, 2010 1:55 pm
ive tryd the links on the help page. i cant figure the model of the carb.its a carter bbd 2 barrel with no tag just number on carb say 0-2299 or 6- 1984.
ive looked at other but mine has the plunger at the top of the bowl all the others have a shaft that stiks from the side.if it helps i found one on ebay but still no model ...this is exactly wat style mine is can anyone identify it so i can get a rebuild kit http://cgi.ebay.com/ebaymotors/Carter-B ... 201wt_1165
thanks jim
p.s and of course it on my 225 slant 6
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Wed Dec 08, 2010 2:45 pm
I am not sure on the 2bbls but the 4bbl Carters the number is also stamped on the area near the throttle plate. Be that as it may most rebuild kits cover many models and you will always have extra parts left over. If this is a 2bbl from a super six set up most likely any kit for that application will work-you just will not know which specs to adjust to. So when you take it apart measure everything, write it down, take photos and then clean and re assemble.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Wed Dec 08, 2010 7:14 pm
'66 or newer Up to 70-71-72?
'65 was the first year for the PCV fitting. They hand no provision for attaching an air cleaner. They used a band that tightend arounf the neck.
I think '73 was the first year of the plastic fitting on the top for the bowl vent.
Air metered carb. Parts won't swap with a super six. Rods and jets won't swap.
It would be a good carb for a slant.
That is possibly for a Poly 318.
If there isn't a tag there is no way to tell the model.
When rebuilding the carb you need to flatten the top of the fuel bowl, and the carb top. I give mine a ride on the stationery belt sander.
I have some NOS Mopar kits for that style carb.
If you want a kit they are $15+ USPS I will be home middle of next week.
PostPosted: Wed Dec 08, 2010 7:49 pm
Car Model: 1968 A108 225/3 on the tree
when u plan to go through that carb, take it off, take it to ur local parts house, and let them tell u what it is. go to a real parts place, not an O'rielly or the like.
i have one very similar to this and i still don't know what it's application is/was. but i was able to get a rebuild kit. now i keep it as a spare.
PostPosted: Wed Dec 08, 2010 8:02 pm
The kits from Autozone aren't bad. I rebuilt a '65 model for the Duster with one of their kits.
I have the part number at home. I bought a couple before getting the Mopar kits.
SAVE YOUR ORIGINAL GASKETS TO MATCH THEM UP WITH THE NEW STUFF
The generic kits will come with extra pieces. Lots of extra pieces with subtle differences.
 Post subject: Carb
PostPosted: Wed Dec 08, 2010 8:44 pm
Does it say Carter on it? Just asking because the poly's and early 273's had Stromburg carbs that were similar.They didn't have air cleaner studs and a band held the cleaners on. Stromburgs are(were) very good carbs.Got two of them. I don't have a super six intake to see if they would bolt on though.
 Post subject: Re: Carb
PostPosted: Thu Dec 09, 2010 7:38 am
Yes they will bolt on. I had a friend that lent me a Stromberg and it performed as good as my 2280 Holley at the time.
There is a Stromberg out there with a 3 bolt base. It won't fit.
Really for the price that new carb is a steal! If I had the money I would snag a bunch of those.
Every BBD I have has a worn out throttle shaft on the passenger side.
PostPosted: Thu Dec 09, 2010 3:46 pm
See this thread:
http://slantsix.org/forum/viewtopic.php ... highlight=
. . . there was good sport at his making.
PostPosted: Fri Dec 10, 2010 2:50 am
you saying that is a Chinese carb?
PostPosted: Fri Dec 10, 2010 6:06 am
Yup knock off Rally Brand.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Dec 10, 2010 5:18 pm
Frank
Someone ought to try one out. Those carbs would be so easy to duplicate.
Really neat if they interchange parts like my dad's .45 !911 Colt copy
Users browsing this forum: Bing [Bot] and 11 guests
