It is currently Sun May 24, 2026 5:21 pm
PostPosted: Sat Nov 27, 2010 2:29 pm
Well I finally got some new wheels and tires for the '79 duster that I drive everyday.
I got Some 17X8 Bullitt Type Mustang rims and some p245/45/17 Tires off craigslist.
This combo requires the use of a 1.5" spacer to work. So I got the tires mounted on the rims and got the wheels and adapters on the car. They look real good. I might keep them on a day or 2 more before the Winter Studs and Steelies go on for a few months.
Pics:
The old Wheel and Tire combo Weighed in at 41#
The New Wheel And Tire Combination Weighs in at 45#
Plus 4# for the 1.5" spacers.
Spacers installed
Stylin.
Thanks to these folks for their cars / Ideas:
Brian T.
AndyF Look a few replies down on the post.
Cant Forget Lou and Josh Skinner too.
PostPosted: Sat Nov 27, 2010 3:27 pm
1.5" spacers? You must have gotten the later model wheels with more than 30mm offset.
PostPosted: Sat Nov 27, 2010 3:48 pm
I am sure its possible..
I am not all that knowledgeable about the mustang wheels, but I do know that without the spacers the wheels would be hitting some suspension components on my car.
PostPosted: Sat Nov 27, 2010 4:36 pm
The current generation (2005+) Mustangs have higher offset wheels than the previous generation. The 4th Gen 17x8" wheels are all +30mm from what I've seen. They need a 1" spacer on the rear end of an A-body and will fit over the ball joint on the front if the grease fitting isn't too tall.
PostPosted: Sun Nov 28, 2010 4:39 am
Good luck getting it to pass inspection with those spacers Greg.
PostPosted: Sun Nov 28, 2010 6:07 am
Yeah, I kinda thought the same thing.
I have another set of wheels / tires for that purpose.
PostPosted: Fri Dec 03, 2010 7:44 pm
I must be tired, at first glance I thought that scale was your speedometer at first lol
PostPosted: Mon Dec 06, 2010 4:58 am
@ESP47 - Same here.
Looking good!
PostPosted: Mon Dec 06, 2010 6:56 am
looks nice Greg.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Mon Dec 13, 2010 1:39 pm
Thanks Frank!!!
This is the same car that you saw at the banquet last feb...
Now with a bit more style in the non-salt months!
