It is currently Fri May 29, 2026 6:26 pm
PostPosted: Mon Dec 20, 2010 2:56 pm
Hey,
I pulled out the dash of my 67 vc valiant.
now if I turn the key etc it won't start, what wires do I have to connect to what to get this to work....?
Thanks.
PostPosted: Mon Dec 20, 2010 3:09 pm
You need to re-connect the large black & red wires that went to the alturnator gauge.
PostPosted: Mon Dec 20, 2010 3:31 pm
You need to re-connect the large black & red wires that went to the alternator gauge.
Should he just bolt both wires together to each other, or put the Alt gauge between them?
PostPosted: Mon Dec 20, 2010 3:49 pm
Just bolt them together.
You may want to look for the neutral safety switch if automatic.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Mon Dec 20, 2010 3:51 pm
Bolt & nut the two eyes (black & red) together tightly, and tape the splice up using 3M’s 33 electrical tape, “the good stuffâ€￾. You don’t want that wire grounding out & melting everything back to the battery while it is flopping around with no dash to protect it, or its connection coming loose. The amp gage need not be connected.
Users browsing this forum: Amazon [Bot], Google [Bot] and 23 guests
