It is currently Mon May 11, 2026 9:15 am
 Post subject: Piston clearance.
PostPosted: Tue Aug 12, 2003 10:05 am
My machinist suggested that the piston clearance should be a little looser than stock speck on the engine I'm building if I want to race it. I was thinking around .0015 ". What is my best bet? I want to race this car, but I want it somewhat streetable. The engine is .060 overbore, with .502 lift cam from Comp Cams, and I'm expecting 10.5:1 compression.
Thanks.
65' Dart. A work in progress..
______________________
Joe
PostPosted: Tue Aug 12, 2003 11:23 am
Mine are cast replacement pistons (TRW, 0.060) and they are set to the loose side of factory, but that's all I remember. I also used lower tension oil rings, and it only uses 1 qt every 1k miles, or a little less after 45k miles and lots of racing. 6k RPM, no problem...
PostPosted: Tue Aug 12, 2003 11:47 am
It really depends on what type of piston you are using. IIRC, forged pistons need to be looser than cast, and hypereutectic can be about the same as cast. My Slant manual calls for .0015"-.002" for stock pistons. :shock:
PostPosted: Tue Aug 12, 2003 12:07 pm
We just installed a motor with forged 2.2 pistons set at .003 clearance.
I have not started the engine yet so I can't say how it works, may-be next week.
PostPosted: Tue Aug 12, 2003 6:56 pm
I guess I'll just tell him to make it happen. He has built many successful race engines, and is a well respected machinist. Thanks for the input guys.
Joe
PostPosted: Tue Aug 12, 2003 7:38 pm
I just installed a motor with forged 2.2 pistons set at .003 clearance.
You did, or the kids did? :P
Users browsing this forum: skraecken and 10 guests
