It is currently Wed Oct 14, 2026 1:20 pm
PostPosted: Sat Dec 25, 2010 5:29 am
I'm having a tough time locating a kickdown linkage for my super-six setup. Has anyone here manufactured one or modified the 1-bbl linkage to do the job? What's different? I've got a welding rig, so I figure one can be made if I can get some critical dimensions.
1980 Volare, Super Six Intake
PostPosted: Sat Dec 25, 2010 5:36 am
I have asked that a few times. Always ended up going to a cable style (Lokar) setup.
Frank
PS is you get a good clean setup post pictures as more than a few folks would like to make one. :D
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Dec 25, 2010 7:20 am
i haven`t used it yet but i have scraped a couple of mid to late 90`s dakota pickups and the kick down cable with brackets look like a workable setup :idea:
PostPosted: Sat Dec 25, 2010 9:28 am
BEP kick-downkitis about the same as a Dakota factory set up.
PostPosted: Sat Dec 25, 2010 9:40 am
i used a lokar on mine, pretty easy if you are handy.
very old picture, but still the same setup 2 years later
PostPosted: Sat Dec 25, 2010 2:07 pm
Any magnum/auto setup uses this cable. Its the only way to go if you dont want to spend $$$. I had a whole 17.50 in my kickdown that was on my dart. Got the cable and bracket off of a mid 90's 1500 and spent an hour installing it and it worked great.
PostPosted: Thu Jan 13, 2011 11:11 am
Do you recall which Lokar model number you got?
PostPosted: Thu Jan 13, 2011 11:38 am
http://www.summitracing.com/parts/LOK-KD-2904HT/
PostPosted: Thu Jan 13, 2011 10:27 pm
Summit also have extra-long versions of the Lokar cables.
Olaf
Aspenized
