It is currently Mon Apr 27, 2026 3:02 pm
 Post subject: Gas Tank fill neck
PostPosted: Mon Dec 27, 2010 2:00 pm
Does anyone know if the fuel fill tube neck is the same size on a 65 Valiant and a 71 Dart? I only want to use the end to mount my gas cap to. I have a fuel cell in the trunk so I won't be using the fill tube part. I don't want to cut up my original one.
I found one on E-Bay close enough to go pick it up, but didn't know if the ends were the same.
Thanks.
Rick
 Post subject: Filler Tube
PostPosted: Mon Dec 27, 2010 4:53 pm
Hi Rick, The 65 cap hole in the filler tube is a tad bit smaller than the 71.
IE the cap from the 71 won't fit. Just did a 64 Barracuda for a guy that wanted a locking cap. He got a cap for the 67 up car and it didn't fit. We had a extra 64 fill tube and massaged the opening for the cap to fit.
Hope this helps.....
 Post subject: Thanks
PostPosted: Mon Dec 27, 2010 5:25 pm
Yes that is what I wanted to know. I guess I'll just cut mine off and worry about another filler neck if I ever put a stock tank back in it.
Rick
