It is currently Mon May 18, 2026 1:49 am
PostPosted: Wed Dec 29, 2010 2:23 pm
I finally got my stuff together and I am getting my duster/twister back on the road . After checking things out with my trusted friend/mechanic we decied to replace a few little things before we started to tune and get her ready for the streets. After finding a nice crack on exhaust manifold we decided to take it off and repair or fix it. Like most s6 intake/exhaust bolts mine broke when I tried to take them off.I ordered the intake/exhaust manifold gasket kit, a new air filter, valve cover gasket, replacing cracked PCV valve, my wires and plugs have seen very lil use but replaced a 5+ plus years ago. So here is my question were is best place to buy thes exhaust manifold bolts bolts I found some 3/8 at oriellys and that was about it. Any part #'s would be greatly appreciated.
Image[/img]
PostPosted: Thu Dec 30, 2010 8:08 am
I'm not sure of what you need to know the manifold to head studs are 5/16 by about 2". The manifolds are held together by a 3/8" stud and two 5/16 bolts threaded into the exhaust manifold.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri Dec 31, 2010 10:12 am
thanx for info
PostPosted: Fri Dec 31, 2010 8:27 pm
I know I am in australia but they ship overseas.
www.valiantspares.com.au
www.pentastarparts.com.au/sunshop
think for a full set of studs and nuts for manifolds is around $50 AUD
PostPosted: Fri Dec 31, 2010 10:15 pm
You will find bolts and nuts (and new ex. manifold also) at silver-seal.com.
You should also take a look at this link:
Good-sealing intake-to-exhaust gaskets FINALLY available.
Also check out the info in the FAQ at the start of the engine section.
Olaf.
Aspenized
 Post subject: Bolts
PostPosted: Sat Jan 01, 2011 9:36 am
Look for Charrlie_S on this site. He has a New Exhaust manifold with hardware for sale(great price) and would be much better than trying to repair your cracked one. Unless you have some one that is very good chances are that the repair will not hold up. Mine didn't.
Looks like a clean Duster. I seldom see Twisters any more that have the factory stripes still on them.
PostPosted: Mon Jan 03, 2011 8:40 am
thanx for positive responses I found a good exhaust manifold at local pick n pull. I'm going today an hour or so to salvage whatever I can. Im just gonna buy some new hardware thanx for all the positive comments and response I posted some pics in my other post in the sixer's gallery if your interested. 2011 year of the duster.
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
