It is currently Tue May 19, 2026 5:32 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Mon Jan 03, 2011 12:49 am
Since the truck's exhaust is gone (completely), I'm intending to run a 2.5 inch exhaust. The muffler shop said it would cost minimally or nothing more (about 250 total, including the catalyst) to go from 2 inch to 2.5, so that's what I'm doing, and hoping to get a nice sound from it. I don't want it loud.
I have no means of porting the exhaust manifold, however. If I can some up with something, I'd at least port match the int and exh @ the head.
This is not a "maximum horsepower" build, but rather, one to maximize power between 1500 and 3500, with an emphasis on the lower half of that range.
PostPosted: Mon Jan 03, 2011 4:52 am
I don't think you want to match the exhaust. IIRC the floor of it ground out will make it lazy.
I did a build for a friends 81 van. I did the bowls, unshrouded the chambers, opened the intakes 1/8th of an inch bigger than the intake manifold for an anti-reversion effect.
Polished the chambers and took .060 off the bottom. When he ran it through emissions it was very very clean! Non working air pump too!
