It is currently Tue May 19, 2026 12:56 pm
 Post subject: aspen
PostPosted: Fri Jan 07, 2011 10:19 pm
ok what can i d to my 80 dodge aspe to run 14s and cany any body give me info to what body parts may work of other cars and how to hook up a tech
 Post subject: Your plans
PostPosted: Sat Jan 08, 2011 5:31 am
What are your plans for the car? A street car, race car, street /strip car. It will help people to respond. 14's in a heavier car like yours for a street car takes some work.
Rick
 Post subject: info
PostPosted: Sat Jan 08, 2011 6:06 pm
street car its got to beat a crown vic and lsc with a 5.0 thats all and can any one tell me about the body panles and maybe parts
PostPosted: Sat Jan 08, 2011 6:20 pm
Put a 440 in it.
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Sat Jan 08, 2011 6:37 pm
Site Admin
Put a 440 in it.
x2 :lol:
To put that car with the slant in the 14's without stripping it to nothing and dropping five grand in mods is, unlikely. You could for-go the mods and put it on the hose, but your still going to have to strip it down.
CJ
PostPosted: Sat Jan 08, 2011 7:59 pm
I have seen a 440 six pack in one-it fits!
 Post subject: what
PostPosted: Sat Jan 08, 2011 9:10 pm
isnt this a slant six form and funny thing i have a friend with a 440 haha
is there a link for this and i have a 84 supra runs 11s and a 92 camaro 383 lt4 i i have my fast cars i would be happy with 14 70s out of the slant
agin what other cars body parts will fit the aspen nd is there a link for doing a 440 sawp
PostPosted: Sat Jan 08, 2011 9:36 pm
'76 through '79 Aspen and Volare panels should interchange with no problem. '80 Aspens and Volares have different hoods and front fenders.
Check out this site: http://www.aspenandvolare.com/
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jan 08, 2011 9:39 pm
About that 440 swap, Mopar Action had an article detailing this swap several years ago. I'm not sure if there is a link to it though.
However, I would recommend keeping the the slant six in your Aspen. It's your car though.
'78 Volare 225
'67 Charger 318
PostPosted: Sat Jan 08, 2011 9:41 pm
Site Admin
Sure it's a slant six forum. There are a few streetable cars that run under 15's. I personally haven't seen an F-body doing it, but sure, you can do it.
What's your budget? Street Strip, or strip only?
My Hooptie runs right on the edge of 14's. Four door Valiant. One passenger, but it is a fairly heavy place to start. 15.02 best. It still carries it's plates, and all the required things work to make it legal.
Getting further than that with a street car will require power adders if your going to keep the seats and so forth.
If your ready to take some weight out of it, and want to build up a killer slant, take a look through the Articles Section of the site. There is an engine build Matrix in the Frequently Asked questions area of the Engine topic. Peruse those too.
Putting a 440 in the Aspen will be a chore, and it'll handle terrible. There aren't a lot of options for Torsion bars.
Why the specific cars you want to be faster than? Somebody specific your gunning for?
Doing this sort of thing with a specifc car and engine can be a challenge. Both for the budget, and because there aren't any bolt on options like there are with V8 builds.
I've learned a lot about fabrication to get where I'm at. We'll see how the winter's modifications play out with my build. I might just put a 14 something down yet. :D
CJ
PostPosted: Sat Jan 08, 2011 11:43 pm
Mikey in Iowa has an F-body that I believe has run in the high 14's and is a street car. It is not on the ragged edge either.
I went 14-teens in the Valiant at almost 3300#. 150 shot put it at 12.0's.
Is getting your F-body in the 14's going to be simple or cheap? No, but it is not impossible.
There are enough engine builds posted on here that you will find what you need to know with the help of the 'Search' function.
How many wires and what color are on your tech? Normally there are 4 wires. Red-keyed power, black-ground, green-coil negative, and white-dash lights.
PostPosted: Sun Jan 09, 2011 5:02 am
ok thank you Wesola78 Ceej and slantzilla for the info and not to just tell e to put a v6 in it and yes i m guning for two ppl ill smoke the vic but i think the ford lsc going to give me a run i have a one owner 80 dodge aspen door
it was my grandmothers car and she past last year onmy burthday and flet it to me so i would do a v8 but my mine rule is not to cut any thing and im use to no aftermarkit support my camaro use to be a v6 turbo as for makeing the aspen i dont want any power adders
PostPosted: Sun Jan 09, 2011 4:30 pm
Car Model: 1979 Dodge Aspen
I have a Aspen that will run in the high 13 teens I have professional built motor bored 100 over big valves ported head big cam roller rockers granted I spent some money on it and took some time my car is heavy undercoating cc, air, pb ,ps, changed the rear end to a 83/4 it averaged 16mpg on the power tour it can be done any questions let me no
PostPosted: Sun Jan 09, 2011 8:48 pm
I'd say get a buick 231 turbo, a holley 600cfm DP and 4 bbl intake. Used wastegate and BOV. Boost ref regulator and hit the 14's on the first time out. All could be had used on Ebay (or other spots) and done in the $1,000 range or maybe less. No reason to change gears or shoehorn a 440 in the thing. 8) 8)
Goodluck in whatever you are going to do.
Later
Ryan
10.74 @ 127.47 mph 1320 ft
6.65 @ 107.80 mph 660 ft
http://www.youtube.com/c/turbo66valiant
Follow on Instagram - turbo66valiant
Facebook - https://www.facebook.com/ryan.peterson.737
PostPosted: Tue Jan 11, 2011 6:38 am
ok been driveing the car and for so odd resan when u floor it it just falls on its fase and stalls its aremand 1 bbl ill get the # later and what stily lifters do i have sold or roller its a stock 1980 aspen
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 16 guests
