It is currently Sat Nov 21, 2026 4:49 am
 Post subject: engine problems
PostPosted: Tue Jan 18, 2011 3:34 pm
ok so i got this 80 volare running but it has no power and will not idel i am about ready to crush it somebody said that it could be the combution computer does any one no the carb was rebuilt so i was told but it has hesitation and stubles and falls on its face on;y way it will climb a hill is in first gear pullen i r's at 10 mph
PostPosted: Tue Jan 18, 2011 4:27 pm
OK -Do you have any repair experience? Do you have tools? Do you have a vacuum gauge? If you do what does it read at idle? I do not think a 1980 is a lean burn but to be sure do you have a photo of the engine? We can give some advice after these question. I assume that you checked all the vacuum lines coming from the carb. Have you done a tune up?
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
PostPosted: Tue Jan 18, 2011 6:49 pm
i had a similar problem with an 81. still do sorta, but the biggest difference for me was replacing the fuel lines under the hood. mine were dry rotted and sucking a lot of air.
