It is currently Thu Aug 27, 2026 6:36 am
 Post subject: rod oiling
PostPosted: Wed Jan 19, 2011 10:34 am
I have seen recommendations to improve the slant six engine oiling for:
oil pump gear, by running a dedicated line, timing chain, by drilling a jet in the front galley plug, lifters & cam by chamfering the lifter bore and restricting flow,, maybe I have missed it, but I have not seen anyone comment on improving rod oiling by running two upper main shells, as mentioned in the slant six performance article
In high speed, fully modified engines provision must be made for more oil flow through the main bearings to the rod bearings. One way to achieve this is to groove the crankshaft. A better way is to use the upper main bearing shells in the main caps. (It will be necessary to file down the locating tabs to allow the grooves to align.) These tabs merely locate the bearings. The tabs do not prevent rotation; the inserts are "crushed" by the cap to prevent rotation.
anyone doing this?
thanks
PostPosted: Wed Jan 19, 2011 12:05 pm
Several of the board users are doing this (Seymour, Charlie, Doc...), but this is only really recommended or needed for an all out engine (6000+ RPM).
PostPosted: Wed Jan 19, 2011 12:50 pm
I use a Few of the Oil Mods, Especially the Standoffs in the Lifter Galley and The Honing of the lifter bores..
I Do run two Lower bearing halves in my race engine.. I just use a die grinder to remove the tabs and stick them in the upper bearing half.
these mods are only needed in race only type engines.. Street engines mostly are fine with out these mods as Lou said.
PostPosted: Wed Jan 19, 2011 1:58 pm
thanks
PostPosted: Wed Jan 19, 2011 4:47 pm
I had the crank full grooved for full time rod oiling.
11.02 @ 120.56
Chassis dyno
PostPosted: Wed Jan 19, 2011 4:51 pm
i have seen your posts, so I know you are running some real boost,
so why did you choose to groove the crank?
Is it so you could run the standard lower all the way around to get better bearing stability?
PostPosted: Wed Jan 19, 2011 5:58 pm
I figured it was less expensive than buying two sets of bearings if I have to take it apart. There is plenty of crank strength so that was not a concern. The groove is not that deep and cost something like $50 while at the crank grinding shop..
11.02 @ 120.56
Chassis dyno
PostPosted: Wed Jan 19, 2011 6:11 pm
That's what I used to do, except I didn't file the tabs. I modified the notch in the main cap. Just do that one time, instead of doing the bearings every time. Now I do my lower main bearing similar to Doc, except where he does a partial groove, I do a full groove. A lot less money then 2 sets of bearings.
PostPosted: Wed Jan 19, 2011 6:12 pm
PostPosted: Thu Jan 20, 2011 7:51 am
Would this be a suitable modification for an open road racing engine , vs drag racing?
I'm talking about sanctioned, legal events, not speeding or street racing. Sustained speeds, say averaging 80-100 MPH, occasional hills and turns, 60 miles per run, two runs per event, with some shorter practice sessions leading up to the event. Many racers drive to and from the event.
PostPosted: Thu Jan 20, 2011 9:14 am
I would say yes. But more important would be to control the oil in the pan, with a deeper sump/baffles/pickup, etc. No mater what you do to improve the engine oiling system, it does no good, if the oil doesn't get there.
PostPosted: Thu Jan 20, 2011 10:11 am
I agree that this should be good for an open road car.
Shaker, how deep is your groove?
PostPosted: Thu Jan 20, 2011 3:33 pm
It isn't that deep....It has been a while...maybe .050".
11.02 @ 120.56
Chassis dyno
PostPosted: Fri Jan 21, 2011 4:27 am
Dude, that' Groovy.
Sorry Couldnt resist :lol:
PostPosted: Fri Jan 21, 2011 5:19 am
Yep, groove-tastic. Interesting - 0.050" was just the number that I thought would be good when I asked. Thanks, Tom.
Users browsing this forum: Bing [Bot], GTS225 and 7 guests
