It is currently Fri Nov 20, 2026 7:58 am
 Post subject: Another Carb ?
PostPosted: Mon Jan 24, 2011 11:18 am
I am getting a 65 Barracuda with a 225 super six. I would like to put a 4bbl on it and have read most everyone uses a 390 CFM carb. I have a 570 Holley Street Avenger I would like to use after a rebuild. Will it hurt the performance of my engine?
PostPosted: Mon Jan 24, 2011 11:21 am
Yes. Putting a 570 CFM carb on an otherwise stock motor, especially a 65 motor with the older smaller camshaft will just make the motor fall flat on its face. You really don't need a four barrel carb to get good performance out of a slant six unless you are building a dedicated 1/4 racer.
PostPosted: Mon Jan 24, 2011 11:42 am
Thanks Reed I will get the 2 bbl rebuilt.
PostPosted: Mon Jan 24, 2011 12:09 pm
I suppose more info is needed. When you say "Super Six" with reference to 1960s slant sixes, you could be referring to someone installing a "Super Six" two barrel carburetor and manifold from a late 70s era vehicle or you could be referring to the "Super 225" which was another name for Plymouth 225 cubic inch slant sixes.
Is your motor a 65 motor with a two barrel carb and intake? Are there any other mods? Is it a complete later motor swapped into the Barracuda?
PostPosted: Mon Jan 24, 2011 12:44 pm
Yes it is a 65 225 with a Factory 2 bbl and intake,and 904 trans.I wish it had dual exhaust but it doesn't. I haven't gotten it home and don't know the rear gear ratio.
PostPosted: Mon Jan 24, 2011 12:49 pm
Slant sixes didn't come with two barrel carbs from the factory in 65, so you either have someone swapping in a later intake manifold and carb or a whole later motor. Slant sixes never came with factory dual exhaust, but you have several options to get there. Frankly, a single exhaust that is between 2 1/4 and 2 1/2 will flow plenty and weigh less than true dual exhaust. There is a small performance advantage to splitting the exhaust manifold into two groups of three (123 and 456) but it is perfectly fine to have the two pipes join back into one.
PostPosted: Mon Jan 24, 2011 12:59 pm
The intake could have been switched, but the engine is original to the car. I will get the numbers from the intake this weekend.
PostPosted: Mon Jan 24, 2011 4:51 pm
I talked with the owner today and he said it was a original 225 /6 but the intake is in question of what year it's from.
Users browsing this forum: Bing [Bot] and 10 guests
