It is currently Fri Jun 05, 2026 1:57 am
PostPosted: Sat Jan 29, 2011 11:57 am
I have a slant six 225ci with engine numbers that tell me it was stamped November 3, 1964, in a 1962 d100 with blue paint which from what I can tell seems the original paint on it. My question is this, how can i find out, tell, guess at what it came out of? Where there certain models that had the blue for that year? Multiple models?
1962 D100 /6 225 1bbl
PostPosted: Sat Jan 29, 2011 7:11 pm
In 1964 passenger car engines were red, truck engines as you probably know were yellow. Can you post the actual stamping and casting numbers?
PostPosted: Sun Jan 30, 2011 8:26 am
I have enclosed a picture although the numbers may be hard to make out from the picture. 2363430-17 Casting date 11034
Image[/img]
PostPosted: Sun Jan 30, 2011 9:14 am
Looks to me like the motor was originally red. Blue was not used until the early '70's.
The stamping pad under the alternator bracket will have the date code.
PostPosted: Sun Jan 30, 2011 9:20 am
oh, good eye. thanks
PostPosted: Sun Jan 30, 2011 9:25 am
there are numbers stamped on top of block,under # 1 plug
