It is currently Thu Jun 25, 2026 1:17 am
PostPosted: Sat Aug 16, 2003 2:01 pm
Wishbone or a Triangulated 4 link. You can set up the wishbone or the top bars to be adjustable for pinion angle adjustments.
- the rear end locating comes from the triangulation of the top bars or the wishbone (which is just 2 bars that meet before the heim joint instrad of running 2 heim joints on a 4 link)
A 4 link is pretty easy to fab. the 2 bottom bars get bushings and the the top bars get bushings on one end, heims on the other. Pick up a copy of Truckin', Street Trucks or even Minitruckin' and there will be a bunch of trucks in there that are running 4 links for pictures.
<img src="http://www.trikecreative.com/cicustoms/images/Victims/joe_2.jpg"/>
This is a picture of my truck (not a mopar) - the suspension is not done, and it's not a race application, but you get the idea.
<img src="http://www.trikecreative.com/cicustoms/images/Dodge_Project/wishbone2.jpg"/>
This is a different truck - this one has a wishbone... pretty slick, huh..
Joe
My 63 Valiant
http://www.readersrides.com/rides/class ... aliant.htm
<img src="http://www.readersrides.com/slant6-02.gif"/>
PostPosted: Sun Aug 17, 2003 11:35 pm
The top pic is a copy of the GM coil spring suspension. If the bushings are soft and flexable enough, it won't put the housing in too much of a bind while under travel. OK for street use, not the best for drag use because it hinders housing rotation.
The bottom pic looks like a poor design. I don't see a pivot point for the wishbone. If there is, nothing is holding the top of the housing in position. This is a poor design, even for the street. Might work on a show car that doesn't have to function. This does not allow one rear wheel to bump/rebound independantly. The housing can not rotate. There is no way to make a wishbone function as the upper link and give the housing freedom of movement.
Cecil
PostPosted: Mon Aug 18, 2003 7:03 am
You should see it throw sides - it has adjustable air suspension with a fill valve and a dump valve at each corner. The truck can lift one corner in the back about 12" by filling the bag on that corner.
- I know that you cats are probably not into adjustable suspension...
PostPosted: Mon Aug 18, 2003 9:43 am
Yep, not exactly what we are trying to accomplish. :shock:
Neat pics though. :D
