It is currently Thu Jun 18, 2026 12:49 am
PostPosted: Wed Feb 09, 2011 7:25 am
looking to figure our $$$ for a spare build.
who makes high comp pistons with turbo/thin rings for a slant. I talked to Venolia they said $79.95 each to my specs no rings.
anyone else out there make good high comp pistons?
slant six's RULE!
http://www.usajon.com
PostPosted: Wed Feb 09, 2011 2:27 pm
It is really hard to beat the Wiseco / K1 piston & con rod set-up. (7 inch c to c connecting rod)
As far as high compression factory size SL6 pistons... you will need to have them custom made.
PostPosted: Wed Feb 09, 2011 2:46 pm
whats up with 87-88mm turbo pistons..?
slant six's RULE!
PostPosted: Wed Feb 09, 2011 2:50 pm
that looks like aprox $1000 delivered...
slant six's RULE!
PostPosted: Wed Feb 09, 2011 3:46 pm
I had Ross make a set of thick deck 3.5" bore thin ring pistons. They were right at $120 each with pins, and another $240 for nitrous rings. That was buying 8 too.
Most any piston maker will do pistons to your specs. Make sure to ask prices BEFORE you order though. Ross charged $40 a piston to move the pin hole .100". I thought that was somewhat excessive when it was a custom piston anyway. :shock:
PostPosted: Wed Feb 09, 2011 6:02 pm
what compression would that bring a stock uncut head and block too doc? and how much does the combo cost?
PostPosted: Wed Feb 09, 2011 9:18 pm
Getting that looks like aprox $1000 delivered...
The Wiseco / K1 parts will get you 10 - 10.5 to 1 compression, depending on where your uncut block and head are.
