It is currently Fri Nov 13, 2026 8:49 pm
PostPosted: Sat Feb 12, 2011 9:03 pm
I know Standard had a bad batch awhile back. I've had 4 or 5 of those bad out of the box. Finally had one work for ~2 months. The Wells replacement just went South after 10 months. All wiring has been checked over by both myself and my local professional mechanic, multiple times.
I just put a made in China O'Reilly special on it, as that was what was available when I was stranded on Powell Ave., in Portland, OR during rush hour...
Where should I look for it's impending replacement?
PostPosted: Sat Feb 12, 2011 9:06 pm
You need to make it yourself..............
http://www.slantsix.org/forum/viewtopic ... +regulator
PostPosted: Tue Feb 15, 2011 6:50 pm
Bosch do an aftermarket external regulator too,its number is:RE55.theres a few here in oz having no dramas with them on the slants.
Another AP5 valiant still going strong.
PostPosted: Tue Feb 15, 2011 11:13 pm
I've heard good things about Bosch (and I like their carpentry tools...), so I'll have to see if I can find one stateside. Thanks for the tip, Bigall.
PostPosted: Wed Feb 16, 2011 10:25 am
NAPA carries a very nice solid state voltage regulator under part #VR1001, the only down side is that it is $69.99. If you are decent with a solidering iron, I'd probably try making one following thread posted above. The estimated cost of building a VR is only about $10, even the cheapest replacements are 3-4 times as much.
'66 Dodge Dart
PostPosted: Mon Feb 21, 2011 3:37 pm
I had problems using the mechanical regulators too. Then I tried the stock looking electronic ones on Ebay. Wow, great charging with no discharge and flickering headlights and flickering dash lights.
It was only about 19.00 too !
Later I bought a electronic one from Autozone. It is a flat silver looking item and it also works great. But it was 50.00.
But there is a caution. These are stock amperage rated items and have a limit of 60 to 65 amps. If you use any more you will burn them out just like a mechanical regulator. Many of the stock mechanical regulators are limited at 45 to 50 amps.
Maybe you have a high amp alternator that is burning out all your stock rated regulators ?
PostPosted: Fri Feb 25, 2011 4:05 pm
I have seen intermittant shorts form in alternators right at the brushes. They're easy to remove and inspect w/ the alt removed, but you could test them in place fairly easily.
With the field wire(s) disconnected and the car idling, measure the resistance of the alt field to ground - on those alt with 2 field wires it ought to be infinite. Across the 2 field connections it ought to be a few ohms; on single connection alt it ought to be the same to ground.
Unfortunately, the quality of Standard and other brand Chinese-made parts appears to be quite poor. Sometimes you can get lucky and find NOS US-made Standard parts still.
 Post subject: Vr
PostPosted: Fri Feb 25, 2011 4:55 pm
Wells VR706. I have had good luck with them. Around $25.00
