It is currently Mon Jun 15, 2026 3:24 am
PostPosted: Sun Feb 13, 2011 1:02 pm
I'm putting EDIS on my slant and since I don't need the dist sitting down there, i was wondering if anyone had any great ideas for plugging it off without the distributor in place, and sealed to keep dirt / water / etc out?
PostPosted: Sun Feb 13, 2011 1:51 pm
Freeze plug or rubber expansion plug.
PostPosted: Sun Feb 13, 2011 3:03 pm
You might be able to use a distributor hold down clamp and fashion a flat plate plug to go over/in the hole. Otherwise, ditto on on the rubber expansion plug.
PostPosted: Sun Feb 13, 2011 6:15 pm
Well, Duuhhh, as Homer would say. Great idea!
thanks!
PostPosted: Sun Feb 13, 2011 8:38 pm
Weld that bad boy shut!
Kev
PostPosted: Mon Feb 14, 2011 2:37 pm
how about a block off plate/ mount for the coil pack?
 Post subject: Distributor
PostPosted: Mon Feb 14, 2011 3:09 pm
Take a junk points type Distributor housing( Or any that you have laying around) and cut it off and weld a small aluminum plate over the end. Bolt it in with the normal hold down bolt.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
