It is currently Sat Jun 13, 2026 9:15 pm
Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 14, 2011 3:54 pm
Thanks for the help with the transmission. Now onto the motor, it misfires BAD at idle causing it to shake and lope and it smokes, A LOT (white with gassy smell). I changed the intake/exhaust manifold gasket and torqued all the nuts down. I have the air/fuel mixture screw all the way tight and it still runs! Could this be a vacuum leak? Like my EGR valve?
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Mon Feb 14, 2011 4:43 pm
Site Admin
Have you adjusted valve lash yet?
If your dragging a couple cylinders, the butterfly in the carb could be too far open, unmasking the transfer slot. The idle mixture screw becomes inconsequential. The transfer slots will flow more fuel than the idle circuit.
You can adjust the valves roughly cold, not running, back off the idle screw, set the mixture screw 1-1/4 turns out and see what happens.
There should be information about setting valve lash in the FAQ someplace.
:D
CJ
PostPosted: Mon Feb 14, 2011 9:39 pm
Thanks for the advice, well I'm going to limp it across town to my high school auto shop because i don't have the tools to fix it here. Luckily 6 out of my 8 hours there are in shop.
PostPosted: Tue Feb 15, 2011 4:53 pm
Got 3-5 psi of vacuum from the carb and intake manifold. Then I was listening after shutting it down and I heard "plip" "plip" coming from the manifold, took off the egr valve and gas started coming out :shock:
EDIT: got it running better. My friends '89 chevy died so the Slant Six that he hated came to the rescue and after idling for a while it cleaned up like this: http://www.youtube.com/watch?v=9IGU8nB4rRk
PostPosted: Sun Feb 20, 2011 6:55 pm
Ok, so I pulled off the carb and cleaned it and it is back on the car, pulled the valve cover and I'm going to adjust the valves, I noticed that one of the valves seemed stuck (intake) would this account for only 5psi of vacuum, poor idle, and wants to die with any throttle under load, and the needle twitched around when I was testing vacuum
PostPosted: Sun Feb 20, 2011 7:16 pm
I think you found the problem...
PostPosted: Sun Feb 20, 2011 7:28 pm
Ok assuming that the valve isn't bent can I hit it with a hammer to free it up or could it be carbon deposits holding it open? I am going to turn the motor over tomorrow and see if it is stuck
PostPosted: Sun Feb 20, 2011 7:38 pm
I've freed a valve which had something locking it open by hitting the top of the rocker arm with a hammer. That engine had an intake valve so far open there was fuel in the air above the carburetor when that piston came up on the compression stroke.
PostPosted: Mon Feb 21, 2011 9:02 pm
Ok, so the number 4 cyllinder intake valve is barely open, turns o
ut my moms boyfriend has a compression tester this entire time and just hasn't told me, so tomorrow I have to fix my friends chevy truck and then maybe run a compression test on the motor, if it all checks out good any suggestions why it has such low vacuum? Put a new carb to manifold gasket in and new intake/exhaust to head gasket in so I don't know where it could have been leaking from except for the valve cover
PostPosted: Mon Feb 21, 2011 9:43 pm
6 Pack Dart
I suggest putting some oil on the valve stem before you tap it down, you don't want it to stick down in the guide.
Richard
PostPosted: Wed Feb 23, 2011 6:32 pm
So today was a good day :D I got my valve cover painted
Secondly I got the carb (Holley 1920) back on the car after a good cleaning.
I need new plugs, my current plugs are BOSH and they are black
I got the valves set cold (.011 Intake and .021 Exhaust) It got too dark or else I would have ran it and readjusted them hot.
I only set the valve cover on for the pictures, it isn't bolted down yet.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
