It is currently Sat Nov 14, 2026 12:16 am
 Post subject: 904 performance rebuild?
PostPosted: Tue Feb 15, 2011 4:17 pm
I've rebuilt a number of big block 727's but have never touched a 904. I'm sure many of the 727 tricks will transfer to the 904, but are there any specific 904 things I should know. Or is there any posts or websites that deal specifically with a 904 build? Thanks!
________
HONDA MB/T/X SERIES HISTORY
PostPosted: Tue Feb 15, 2011 6:24 pm
You have a pm.
Olaf.
Aspenized
PostPosted: Wed Feb 16, 2011 6:54 am
Polkat
Most of us just put V8 internals in a slant case and call it good.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: '
PostPosted: Wed Feb 16, 2011 11:19 am
If you can build a 727,you'll be fine. The only "GOTCHAs" I can think of would be the Lo-R band. You have single wrap and double wrap bands,and two,maybe three different styles of band linkages.The different combos take different adjustment specs. S/6 904s often used "left over" parts too.Examples are the 68-70 style valve body was used untill at least 74,and V-8 904s got the double wrap band in 71,S/6s it was the late 70s. Be carefull you don't mix up the 904 parking lock control rod with a 727 one.You can use the A-500 front band in a 904,it's 1/8 inch wider,and works well for a heavy duty build.
