It is currently Sun Jun 14, 2026 12:09 pm
 Post subject: pitman arm and idler arm
PostPosted: Sat Feb 19, 2011 3:15 pm
i am trying to get the parts together for my front end rebuild. do i need an idler arm and pitman arm? i already got the pitman arm and now i am wondering if i need the idler arm as well. thanks. car is a 1977 plymouth volare 2 door custom with slant six. should i get new bushings as well?
Dual 2-Barrel Weber Carbs mounted on an Offy intake, dual Clifford headers, 260 degree cam, Carter electric fuel pump, MSD ignition and coil, electric fan.
PostPosted: Sun Feb 20, 2011 5:21 am
Hard to tell unless you check play in idler and bushings. Most likely, yes. Idler arm usually wears out before the pitman arm.
 Post subject: suspension
PostPosted: Mon Feb 21, 2011 6:50 am
thanks lou.
