It is currently Fri Jul 17, 2026 8:10 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Tue Aug 19, 2003 12:53 pm
No one else has suggested this, so I will. It could be that one of the internal diodes are bad. This would cause the output of the alternator to drop (at low rpm) output; it would only be generating power for 2/3 of each rotation. Check the diode pack, have it checked on a tester that can verify allthe diodes are working, or hook it up to a scope.
My truck is a Frankenstein creation
Built from the dead carcasses of others
And brought BACK TO LIFE!
PostPosted: Tue Aug 19, 2003 10:25 pm
How would I go about hooking it up to a scope?
PostPosted: Tue Aug 19, 2003 10:32 pm
How can you see a bad diode with a scope, since there are 2 others there as well?
You can take it to the same parts store you bought it from and have it tested I bet. Most kragens etc have alternator testers
PostPosted: Wed Aug 20, 2003 5:54 am
You hook up the scope to the output of the alternator. Most automotive alternators are built as 3phase generator; so require 3/6 diodes. The output has a strong ripple on it at the alternator and you can see each of the diodes working. If one is bad, there will be a timed dead or flat spot in the ripple that you can pick out.
Of course, the easiest thing to do is go to the autoparts store and have them test it...
remember, I'm a physicist/engineer/programmer and can't help being a little geeky sometimes (just whip out your scope and the laptop to analyse the signal...)
PostPosted: Mon Sep 01, 2003 11:20 pm
Jopapa,
You worry too much! I've been working on electrical systems for over 30 years and I can tell you that many systems go down to 12v at idle. It is more important that it doesn't go over 14.4 when charging.
Chuck Rivers, Webmaster
Image Image Image Image
