It is currently Sat Jun 13, 2026 4:39 am
 Post subject: 2 barrel super six ?'s
PostPosted: Wed Feb 16, 2011 10:32 am
If I was to get a super six setup what carb would be best for the cheapest price? And which carb would bolt up good with the stock super six kickdown and linkage?
Duster 225
0.30 Over
Headers
Super Six
PostPosted: Wed Feb 16, 2011 11:59 am
You will want to read THIS first. I think you will find the answers you seek. If not, the board search function will net you thousands of results on the topic of super sixing your car.
If you still can't find what you are looking for, we would be happy to point you in the right direction.
You will be looking at a Carter BBD, or a Holley 2280 for stock units, though many many people have used non-stock units on stock manifolds with success. Those 2 will bolt directly to the manifold, and to linkage so long as you have the correct linkage.
:wink:
~RDE~
PostPosted: Thu Feb 17, 2011 8:49 am
Thanks ;)
Duster 225
0.30 Over
Headers
Super Six
PostPosted: Thu Feb 17, 2011 11:43 am
if the numbers are correct on this one
this is a 2280 holley
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
i know a few people have bought a few of them from here... its a great looking carb, just got mine recently, havent used it yet but we measured and the like and it fights perfectly in my 74 duster.
74 plymouth duster, 225 single barrel slant six
PostPosted: Thu Feb 17, 2011 3:41 pm
i just super sixed my van, put on a holley 2280 and im very very happy.
PostPosted: Thu Feb 24, 2011 8:18 am
Looks like ill pick up a 2280 then, seems like the carb of choice :) Thanks guys
Duster 225
0.30 Over
Headers
Super Six
PostPosted: Thu Feb 24, 2011 10:40 am
Is anyone able to verify if this is new or remanufactured?
PostPosted: Thu Feb 24, 2011 11:45 am
Thats the exact one I got, from them as well. Its great.
PostPosted: Thu Feb 24, 2011 11:54 am
actually i read that wrong, i believe theyre new.
PostPosted: Thu Feb 24, 2011 3:47 pm
The one I got was a REMAN but he got a pallet load of them and MOST are NOS according to the lister.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Feb 24, 2011 4:04 pm
and if you need a two barrel air cleaner i have a couple i want to get rid of.
 Post subject: Air Cleaner
PostPosted: Sat Feb 26, 2011 10:44 pm
Car Model: 64 Valiant Convertible, 64 Valiant 2dr Post, 64 va
I' really need a 2bbl air cleaner. I PM you a message
Thanks
RJ
PostPosted: Tue Mar 01, 2011 10:39 am
May be a dumb question but does the 2280 have the thermostatic choke like the BBD? I have a remanufactured BBD on my super six but feel it either needs to be re-built or replaced.
1963 Plymouth Fury 4-door, 225 /6, 3-speed manual w/ OD, "super six", Mopar electronic ignition
PostPosted: Thu Mar 03, 2011 9:37 am
Not quite sure what you're asking. There is no thermostat on the 2280. It has a bracket on the choke shaft, to which you attach the linkage running up from your choke thermostat.
PostPosted: Thu Mar 03, 2011 12:51 pm
Excuse my ignorance, I really don't know a ton about carbs but I thought I read somewhere the BBD has a "thermostatic" style choke that operates based on manifold temp...although there isn't a thermostat (that I can see) running from the manifold to the carb.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
