It is currently Mon Jun 15, 2026 4:27 am
PostPosted: Tue Feb 22, 2011 11:29 am
Check the ignition base timing first.
It should be something like 2 1/2 to 5 degrees BTDC I believe not not positive.
Next, check to make sure the vacuum advance in the distributor is working and is advancing the timing.
Then check to make sure the centrifugal advance is working.
These are the first and most economical places to check for something like this.
PostPosted: Fri Feb 25, 2011 7:52 pm
i have been read about carb jet maybe you guys can educate me on how that work to get better gas milage if i get a smaller on the better the gas milage is right ??
PostPosted: Fri Feb 25, 2011 8:06 pm
6 Pack Dart
Some times it helps some times no.
Richard
PostPosted: Fri Feb 25, 2011 8:52 pm
what did the stock 1945 carb come with
PostPosted: Fri Feb 25, 2011 9:56 pm
6 Pack Dart
I don't know as the only ones I have had on my stuff have been the holly front bowl carbs (they used to be called "fish bowl" because many years ago they had glass float bowls) talk about safety risks.
Richard
PostPosted: Fri Feb 25, 2011 10:04 pm
My 1945 came with a #61 jet.
 Post subject: Two sizes
PostPosted: Sat Feb 26, 2011 12:53 am
1974 #58 Jet
1975+ #61 or #612 close limit jet
Which ever jet you use, you have to change the linkage settings on the carb to match the year/jetting you installed.
PostPosted: Sat Feb 26, 2011 9:23 am
how do i go about getting linkage for 76 duster
PostPosted: Mon Feb 28, 2011 7:51 pm
so i will look for one if anyone can help me out that would be great
PostPosted: Mon Feb 28, 2011 7:56 pm
Site Admin
Which linkage are you looking for? Throttle? Kickdown? What specifically is the problem?
CJ
PostPosted: Mon Feb 28, 2011 10:44 pm
I agree with Newport77. Do the easy & cheap stuff first, especially you go hauling off and taking a carburetor apart. I'm assuming that you're not using the two position throttle. That makes any engine get poor fuel economy.
My repair manual shows that timing should be set at TDC for the 225.
While making these checks, look for vacuum leaks. Cracked hoses and plastic fittings are among the usual suspects.
You can't fix stupid. - Ron White
PostPosted: Tue Mar 01, 2011 7:43 am
Throwing parts at it wont likely solve your issue. You should go to get it looked at by one of the guys near you if you don't feel comfortable doing it yourself.
Trust me, Fopar doesn't bite... much...
:mrgreen:
~RDE~
PostPosted: Tue Mar 01, 2011 8:23 am
6 Pack Dart
"Which ever jet you use, you have to change the linkage settings on the carb to match the year/jetting you installed."
Rob (DI) was telling you to SET the linkage to match the year of the jetting size, not to get a different linkage set-up. You have my phone number, give me a call.
Richard
PostPosted: Mon Mar 07, 2011 5:10 am
what should my vaccum gauage read on it
PostPosted: Mon Mar 07, 2011 8:29 am
6 Pack Dart
Some what near 20" at idle, if the motor is stock.
Richard
