It is currently Fri Jun 12, 2026 5:10 pm
 Post subject: Piston height?
PostPosted: Mon Feb 28, 2011 5:15 pm
So what is the standard piston negative deck height on the very early 70's 225's? The average seems to be .160" down in the hole. Does that sound about right?
________
Maryjane
PostPosted: Mon Feb 28, 2011 5:20 pm
Yes, that is about right... but measure your actual engine to find your exact height.
I have see some engines go as deep as -.210 and some right at -.140.
Most are in the -160 to -.180 range.
Bottomline, actual static comprssion ratios were "all over the map" with a factory SL6.
Users browsing this forum: Ahrefs [Bot] and 3 guests
