It is currently Sun Jun 14, 2026 8:45 am
 Post subject: Idle Mixture Screws
PostPosted: Mon Feb 28, 2011 5:08 pm
Car Model: 1966 DodgeDart
I'm tearing down my carter BBD for a rebuild. When i removed the idle mixture screws ,One was longer than the other& Had more taper than the other. The shorter one was broke was able to push the tip back w/ a pencil eraser and it fell out. In all my diagrams it shows them both to be the same. WTF?
Any one else run into this ,Does this matter? I am ordering new ones If they are the same i will reinstall in correct locations. I did document which side had long & short,Can anyone HELP!!
PostPosted: Mon Feb 28, 2011 5:30 pm
They are not original - or at least one of them is not, when you get the new ones, you will see that they should be of equal length.
Olaf.
Aspenized
PostPosted: Mon Feb 28, 2011 5:54 pm
I have 2 Carter BBD high tops,while both have the same length screws in each carby,from one carb to another they are different tapers.These aren't the super six ones.
DRIVE IT,DON'T HIDE IT
PostPosted: Mon Feb 28, 2011 6:55 pm
They should both be identical. A good carb kit from Daytona Parts will have new needles in it (and a redesigned inlet needle/seat for better fuel control)
PostPosted: Mon Feb 28, 2011 7:53 pm
I should have known to check with the expert's here first. I will remember Daytona from now on. I suspected as much about the screw not being original. brings to mind not to buy reconditioned.
In youth we learn in Old age we understand. I think this site is by far one of the best I have come across for information.
Once again thanks to all of you here at Slant Six .
PostPosted: Mon Feb 28, 2011 8:47 pm
In youth we resent and protest being forced to take naps.
Once we turn thirty, we want back all those naps we refused to take.
PostPosted: Mon Feb 28, 2011 9:39 pm
Car Model: Toad Wagon
:lol:
.... and past 60 they take us.
ps. Thanks for the link.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Mon Mar 07, 2011 5:35 pm
Just an update. Still trying to get screws from Daytona Parts. The Long Screw will not interchange in the base w/ the short side . Kinda figured thats right, makes me wonder what I got from the rebuilder all those years back.
