It is currently Fri Jul 17, 2026 11:01 am
PostPosted: Thu Mar 03, 2011 11:49 am
Good day to all, I've built a slant with a street /strip theme in a four speed. I'm wondering what to run for ignition? I would like to know what to run for an ignition box?, I would like to have one with a rev limiter if possible since a missed shift is inevitable.
My stock combination had already been upgraded to Mopar electronic (orange box) When the engine was run on the dyno I used the stock distributor with the electronic pick up but they had their own MSD on the dyno. My engine has slightly over 10 to 1 compression, what is the best box for this application?Is the Mopar stuff sufficient? Or an upgrade a must?
I appreciate any and all comments.
Thanks Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Thu Mar 03, 2011 3:02 pm
Easiest thiong to do to get a good box with a limiter is to get an MSD-6AL. The L means limiter. You can run it off your stock Mopar EI distributor.
PostPosted: Thu Mar 03, 2011 5:10 pm
The Crane Hi-6 ignition is another good option. I've been using one for a few years now. It's very good. Pretty much the same thing as the MSD-6AL but the Crane is digital and has dials to set rev limit instead of plug in rpm chips. The Hi-6 also has a few other neat functions, tach test mode is one, used for testing tachometer and shift light accuracy without even starting the engine.
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Thu Mar 03, 2011 5:29 pm
I have had problems getting MSD accessories like the rev limiter to work with the Chrysler ignition. I finally put in a 6AL and it has worked well since with lots of street driving. Not that much more expensive than buying all the add on do-dads.
PostPosted: Fri Mar 04, 2011 4:16 am
Thanks for the input from everyone, I'll look into both of these. The dial option sounds appealing.
Thanks again Derek
PostPosted: Fri Mar 04, 2011 3:21 pm
Summit has a rebadged version of the Crane Hi-6 (I'm assuming this because it looks the same with all the same features).
The only difference I can see is that the Summit version doesn't have a CARB EO number...
PostPosted: Fri Mar 04, 2011 11:32 pm
I just had a look on the Summit website, the Summit box has a much lower spark output compared to the Crane Hi-6. Unless it's a typo. :?
PostPosted: Sat Mar 05, 2011 1:02 am
It's probably a Chinese knock-off. :shock:
