It is currently Sat Jul 18, 2026 7:45 am
Post new topic  Reply to topic  [ 78 posts ]  Go to page Previous 1 2 3 4 5 6 Next
PostPosted: Thu Mar 03, 2011 11:02 am
I emailed the pics to Doug. When he posts them I go thru and narrate them.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Mar 03, 2011 1:37 pm
here is a link to FABO for all the pics!
http://www.forabodiesonly.com/mopar/sho ... ost1287612
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Thu Mar 03, 2011 5:00 pm
Poser
Thanks for the link! What do the ports look like?
PostPosted: Fri Mar 04, 2011 9:25 am
Wayne
I wish I could get a picture to do them justice. All I can say is NO obstructions at all. a smooth and LARGE port on both intake and Exhaust.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Mar 04, 2011 9:49 am
Poser
Thanks Frank! Man it would be good to get it to a flow bench. Thanks for the pics.
PostPosted: Fri Mar 04, 2011 10:50 am
I'm a little confused about the rocker shaft perches. They look flat on top rather than cylindrically concave. Different rocker shaft setup...? Or am I not looking correctly at the photos?
PostPosted: Fri Mar 04, 2011 1:10 pm
Yes, flat on top for bolt-on adjustable-height rocker stands.
PostPosted: Fri Mar 04, 2011 2:27 pm
There's some Jeffrey heads out there that have no rocker stands at all on them.
PostPosted: Fri Mar 04, 2011 3:38 pm
Mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm..............OK now I,m in the mood to work on my slant projects :D :D
Nick
86 d150 turbo /6.
PostPosted: Fri Mar 04, 2011 5:30 pm
http://i690.photobucket.com/albums/vv26 ... 020548.jpg
PostPosted: Sun Mar 06, 2011 6:30 am
The plan is to flow test the head as soon as I can get to Memphis.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Mar 06, 2011 6:33 am
Thanks for the pic, Will.
Frank, we'll all be interested in flow numbers...
 Post subject: numbers!
PostPosted: Sun Mar 06, 2011 12:46 pm
Are you there yet? What's the hold up!! :lol: :lol:
PostPosted: Sun Mar 06, 2011 4:19 pm
I was on holiday! Im glad the head arrived perfectly Frank! Hope you can push a lot of horsepower with this!
Thank you so much for your trust.
Men are not jugded by the way they fall, but by the way they get up
PostPosted: Mon Mar 07, 2011 4:29 am
Frank
the "added material' around the combustion chambers in the close up views appears in the photos to have a different gloss than the remaining firedeck area. Is that the same appearance in person? If so, are the closed in combustion chambers welded material?
certainly a nice find,, and the dragster is just as cool!
