It is currently Tue May 26, 2026 11:32 am
 Post subject: suspension question
PostPosted: Tue Feb 08, 2011 12:58 pm
so i have got my torsion bars and my edlerbrock ias shock and i am going to rebuild the front end do i need to get new clips for the torsion bars?? also i was wondering what would be a good size sway bar
 Post subject: Re: suspension question
PostPosted: Fri Mar 04, 2011 8:42 pm
I've re-used intact clips with no problem. Make sure clip sits in groove fully. (True if using new or used clips.)
I'm using a combination 1¼" front bar and a 1" rear bar. If you're not going to install a rear bar, I recommend nothing larger than a 1 1/8" bar. This is assuming you have the factory sway bar tabs on the LCA.
You can't fix stupid. - Ron White
