It is currently Fri Nov 13, 2026 10:54 pm
 Post subject: Holley 1920 Carb ID
PostPosted: Sat Mar 05, 2011 3:09 pm
Poser
SSD and others, help! Trying to gather up some carbs so I can hopefully find a rebuildable pair for a Offy dual 1bbl set up (5041). Maybe someone can tell me if I have a couple compatable match.
Carb 1
1 5/16 12R-7611B (side of Bowl)
6260 2
0356 stamped on vertical surface along same plane as Holley marking
Carb 2
1 5/16 12R-7611b (side of bowl)
6260 2
0987 #'s found in same local
carbs 1&2 look almost identical Maybe thats why the #'s are similar. duh.
Carb 3
1 5/16 12A-5592B
6594 2582
3698347 same place as above
263 26 #'s facing the sky
Carb 4
1 5/16 12A-4285B
0422
05156
4392 #'s facing sky
Carbs 3 & 4 are earlier (I think). Carbs 1 & 2 were recently purchased from the Bruners. Hopefully you expert types can tell me the application and whether or not I have two that will work as a unit. Thanks, Wayne.
 Post subject: Re: Holley 1920 Carb ID
PostPosted: Sat Mar 05, 2011 8:34 pm
6594: 1973 225/auto, Federal emissions (with EGR)
6260: Go fish, not in my list at the moment
4392: Go fish, not in my list at the moment
I don't have my master Holley book with me; I could swear I've seen 6260 before. Think it might be a service replacement carb for '67-'72 applications. If nothing else, you've got two same-number carbs, a decent start (though two new matched carbs would be better).
PostPosted: Sat Mar 05, 2011 8:58 pm
Poser
Dan, thanks for the help so far. I have a couple more 1920's on the way and have my fingers crossed.
