It is currently Thu Jun 25, 2026 2:51 am
 Post subject: Head interchange
PostPosted: Wed Mar 09, 2011 5:32 pm
Will a head off an 80's engine (hydraulic cam) work on an older block, say from '66?
PostPosted: Wed Mar 09, 2011 5:54 pm
6 Pack Dart
My best guess is if you change the rocker arms, yes.
Richard
PostPosted: Wed Mar 09, 2011 5:58 pm
Yes, it will work. You'll need to use the mechanical valve gear from the solid lifter engine, but with the rear-most hold down bolt from the late head. The '81+ valve cover will need to stay with the head.
PostPosted: Wed Mar 09, 2011 6:36 pm
Would one be better than the other?
PostPosted: Wed Mar 09, 2011 6:59 pm
The later heads have induction hardened exhaust valve seats which are more wear resistant. The '67 and newer heads have an improved combustion chamber.
http://www.slantsix.org/articles/combus ... hamber.htm
