It is currently Mon Nov 16, 2026 1:53 am
PostPosted: Fri Mar 11, 2011 11:02 pm
Anyone ever run their slantsix thru smog testing?
I have a 91 D150 with a 318.. its tired and can't pass smog now. Its allowed 160ppm on the HC and its blowing over 200 with a new cat. It also only ever got 10-12mpg..
I have a few good slants and was thinking of swapping one in.
Has anyone ever smog tested their engine and have some numbers? I need to know if a slant has a chance of hitting 1991 numbers.
I can't really justify rebuilding the 318 because the value is so low on the pickup and it gets such crap millage.
PostPosted: Sat Mar 12, 2011 3:47 am
Yes, but only at idle:
HC ppm: Vehicle reading 261
Max allowable: 968
Average passing reading: 202
This was with a decently tuned slant in a 72 Dart, with an (converted) electronic ignition. For some reason I thought I'd do better than average...
This is with no Cat. The paper also says I should get 100kms out of 9.4 litres of gasoline... Seems a bit optimistic :D
PostPosted: Sat Mar 12, 2011 5:00 am
25mpg :) maybe on the highway
PostPosted: Sat Mar 12, 2011 5:58 am
Long time no post Mr Chrome Alternator......
