It is currently Thu Jan 01, 2026 5:28 pm
PostPosted: Sat Mar 12, 2011 11:02 am
What I know:
Clifford Alum Valve Cover
New looking springs and retainers
Offy intake with 1406 Edelbrock with COAT HANGER throttle linkage that opens about 1/2 way.
Long tube headers
Mini starter
Rumpy-rump cam.
8-3/4 axle
Has sway bars front and rear
Disk brakes with power booster
What I don't know:
What's inside the engine-
what cam, pistons, compression, valves, etc.
What I was told:
'Spose to have 3:91 gears
'Spose to be a 727 TF
How it runs:
Lousy, lazy on bottom, my stocker seems much stronger. Pulls pretty hard on top but shifts back out of powerband.
I have a lot of investigating to do. I got the car for its parts to use on my '63. I plan to pull the engine and pull the head and pan and just see whats in there. Interesting project anyway.
PostPosted: Sat Mar 12, 2011 12:50 pm
As far as the trans goes, look down at the base of the dipstick, If the corner of the pan is square it's a 904. If it has a kick-out it is a 727.
PostPosted: Sat Mar 12, 2011 2:10 pm
Thanks Zilla, I will look at that.
I adjusted the valve to .018 intake and .022 exhaust and she runs a bit stronger now. We shall see.
PostPosted: Sat Mar 12, 2011 7:30 pm
kick out .....727 it is.
PostPosted: Sat Mar 12, 2011 9:18 pm
Car Model: 1984 D100 Shorty Custom
Where are you located? Are you planning on getting rid of the car? Dank10Fenny on the board here is looking for Valiant front clip parts.
He is rolling around the Portland area somewhere IIRC...
~RDE~
President - Cherry City Bombers CC
PostPosted: Sun Mar 13, 2011 7:41 am
Yes I am planning on scrapping the shell after I get all I want off it. THe front clip is nice, it might be from a duster.
I am however a LONG way from Portland as I an in Rome, GA
PostPosted: Sun Mar 13, 2011 9:27 am
How it runs:
Lousy, lazy on bottom, my stocker seems much stronger. Pulls pretty hard on top but shifts back out of power band.
Sounds like too much cam combined with not enough static compression. (low DCR)
Keep loosing the valve lash until it clatters, then tighten-up a touch to make the noise go away.
Can you get a cranking compression reading?
PostPosted: Sun Mar 13, 2011 10:09 am
OK, I checked no. 3 and got 155 psi, what say ye Doc? That's on a stone cold engine.
PostPosted: Sun Mar 13, 2011 11:28 am
OK, took her for a drive and got her good and warmed up. Came back and loosened all the rockers per Doc's instructions. Checked compression warm on same cylinder only got 140. Seems I am bleeding off my compression. I guess I will yank it next and see what's going on.
PostPosted: Sun Mar 13, 2011 12:38 pm
How it runs:
Or too tight of a converter.
PostPosted: Sun Mar 13, 2011 1:23 pm
Yup, could be both. I did drive it with the valve lash opened up to the max and the low end power improved noticeable, no doubt that helped.
