It is currently Thu Nov 19, 2026 10:15 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun Mar 20, 2011 6:36 pm
An old farmer's trick I still use to remove rust is molasses. Get a big tank, use a 4:1 ratio of water to molasses, and dunk the rusty bits in. Come back in about 3 or 4 weeks. As molasses ferments it has a chelating effect. I've dunked rustier parts than those in molasses and they came out looking freshly cast! I would suggest the traditional methods of hot tanking for the crank, head, and block, but i'd bet the rest will come out looking new!
PostPosted: Mon Mar 21, 2011 10:38 am
block is toast. looks like it was involved in an accident. it is cracked major with the dist being pushed in , also next to last cylinder has a major crack up/down. will post pics later.
slant six's RULE!
http://www.usajon.com
PostPosted: Mon Mar 21, 2011 11:46 am
scrap metal... or shine it up real nice, turn that sonofabitch sideways and shove it up... I mean, lay it on the living room floor and make a coffee table out of it :)
PostPosted: Mon Mar 21, 2011 12:48 pm
Too bad it wasn't a 198; at least you could have saved the rods.
PostPosted: Tue Mar 22, 2011 12:38 pm
slant six's RULE!
PostPosted: Tue Mar 22, 2011 3:25 pm
Doesn't look like the exhaust manifold is cracked. I'll bet the head is salvageable especially if oversize valves are used.
