It is currently Fri Jul 17, 2026 12:14 am
 Post subject: bottoming out
PostPosted: Thu Aug 21, 2003 9:35 pm
have a 73 swinger. new shocks all around. on a not too bad bump the right front bottoms out. are the torsion bars bad or what else could it be
thanx
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Fri Aug 22, 2003 7:37 am
Does that side sit lower than the other... Park it on a flat slab and sit down in front of the car and check.
- Your probably right about it being the bars. There are aftermarket ones that you can get that will stiffen up the ride for better handling and ones that are closer to OEM.
Joe
My 63 Valiant
http://www.readersrides.com/rides/class ... aliant.htm
<img src="http://www.readersrides.com/slant6-02.gif"/>
PostPosted: Fri Aug 22, 2003 10:24 am
would i be better off putting some v8 torsion bars under it?
PostPosted: Fri Aug 22, 2003 11:44 am
Junk yard springs will probably be worn out - or the springs you put on might be bad too...
- You might try adjusting the springs before you try anything else. The spring rate can be adjusted on Torshon bars...
Joe
PostPosted: Sun Aug 24, 2003 2:01 pm
it sits level and there is about 6 inches between the tire and the top of the wheel well so they're pretty much adjusted as far as they'll go. the fronts too high the rears too low .need to fix it
PostPosted: Sun Aug 24, 2003 5:15 pm
You might start shoping for a set of aftermarket bars....
Joe
Users browsing this forum: Amazon [Bot] and 3 guests
