It is currently Wed May 20, 2026 5:44 am
 Post subject: Lowering blocks
PostPosted: Fri Mar 25, 2011 4:26 pm
Can some one tell me where we can get some blocks to get the car down in the rear. Car is 69 Valiant. Thank's Smokey.
PostPosted: Fri Mar 25, 2011 4:38 pm
Lots and lots of places have them. Make sure they are 2 1/2" wide and are not die-cast. The die-cast ones break. I used cast iron "lift" blocks from Summit and ate the weight penalty.
 Post subject: blocks
PostPosted: Fri Mar 25, 2011 6:21 pm
Thank's for the info. Are they for the 7 1/4" rear end ? SMOKEY.
PostPosted: Fri Mar 25, 2011 6:30 pm
They are for 2.5" wide leaf springs.
 Post subject: axel
PostPosted: Fri Mar 25, 2011 7:56 pm
I got the spring size. Looking for axel tube size. Thank's .
PostPosted: Fri Mar 25, 2011 10:09 pm
Irrelevant.
PostPosted: Sat Mar 26, 2011 11:03 pm
Need to buy new U-bolts long enough to handle the blocks?
I will measure the tubes on the 7-1/4's piled under my back deck tomorrow for you! :lol: It's too dark right now.
Perhaps somebody can chime in that knows off the top of their head before then. :wink:
PostPosted: Sun Mar 27, 2011 6:28 am
Early 7.25' ( small Bolt Pattern) Use smaller axle tubes - Either 2.75" or 2.5" tubes.
The later ones (big BOLT Patt) use the more standard 3" axle tubes Like the 8 3/4"
Just take one u bolt off even if it breaks and take to any local spring shop, They can make u bolt for you usually while you wait.
 Post subject: low blocks
PostPosted: Sun Mar 27, 2011 10:59 am
Thank's two all for the help. SMOKEY.
