It is currently Tue Oct 13, 2026 3:17 pm
 Post subject: Carb
PostPosted: Sun Mar 27, 2011 4:56 pm
I've sourced an original intake that's been made (professionally) into a 2bbl. and it's an east west configuration.
I was going to get a 350 holley, and then decided to go to the 500 2bbl holley (far as I'm aware it's same as the 350 just minor changes?).
Question is, will this car work with the 500cfm and not be a terrible drive, until the other work has been done? The car is un registered but I like to drive it a little from time to time. At the moment car doesn't go past 3000 rpm, (current carb is bad).
This is the engine build so far.
port and polish
new ignition + bigger coil
Headders
Plan to, Up compression ratio + bigger valves 1.7 1.44 valves. Then finally, new cam.
PostPosted: Sun Mar 27, 2011 6:48 pm
Site Admin
The 500 will be a pain in the butt, and will not work well as a driver. You will need to build a pretty wild slant to work with it.
The 350 will provide much better driveability once you get it tuned in.
2¢
CJ
PostPosted: Sun Mar 27, 2011 7:47 pm
I agree with with Ceej. If you were planning an all out race engine then maybe the 500 would be the way to go. The 350 will be more than enough carb for a street/strip engine.
62 Valiant, 225cid Slant 6/PB 904 with lots of good bits
http://www.moparmarket.com/readersrides ... user=SV162
PostPosted: Mon Mar 28, 2011 12:28 am
Thanks guys, I'll do that then, Since it's the original manifold changed to fit a two bbl. Think I will need a new kick down linkage?
PostPosted: Mon Mar 28, 2011 4:50 pm
Site Admin
Yes. You will need the chrysler throttle lever adapter to operate the carburetor fully, and some form of kickdown. I like the Lokar cable. There is another manufacturer that makes a cable folks like also, but I don't know the name of it.
You can build a mechanical one to operate the TV on the transmission as well.
CJ
PostPosted: Mon Mar 28, 2011 6:55 pm
CJ
Buchillon (sp)
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
